Insulation Testing Problems | Page 2 | on ElectriciansForums
Discuss Insulation Testing Problems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Everything does work not just the TV, Sat Dvd Etc .
Even if it wasnt DP then surley L&n - cpc couldn't fry the Tv. Could it?
If it is a modern Flat screen TV then there should be a surge protection device in the back and it will be internally fused??
Not all switched fused spur units are DP. An SP unit can be used on a tv like above and a DP unit must be used for boilers etc. Lets not assume its a DP on this telly but it still would not make a difference at 250V DC.
I know its common practice to use a lesser voltage, but you should be using 500v, if you turn back time use 1000v just for the luck the TV breaks hehe....
Reply to Insulation Testing Problems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Very technical :D
