Integrated Kitchen units/isloation | Page 2 | on ElectriciansForums
Discuss Integrated Kitchen units/isloation in the Australia area at ElectriciansForums.net
G
greeny
Hi all,
Is a double pole switch above the work surface feeding a 13amp socket below for example a fridge, as good as an FCU.?
The fridge has its own fuse in the plug .
If you use an FCU there are two fuses involved.
I can see that if the fridge was hard wired to an FCU , ie no plug with and fuse then that would be good for isolation and fuse protection/changing
Greeny
Are you going to call on the warranty if you damage the plug top or just change it?
Got to be honest I didn't think it would invalidate the warranty.
nope, rocker I can't think of anything either.
Reply to Integrated Kitchen units/isloation in the Australia area at ElectriciansForums.net
As an aside. I have seen patress/sockets fitted upside down under kitchen units with an appliance plugged in. The sockets were firm and not moving...
