Gavin John Hyde
Patron
Just read an interesting albeit brief story on a fire in Bristol.
Looks as if the DNO cut out caught fire.
its rare for a cut out to go up,more likely a loose wire on one of the tails to or from meter.
looking at the images the incoming supply has been cut back and nothing is left.
i like the advice they give to maintain the cut out but officially not to do it yourself!
Firefighter's warning after fire erupts in electrical box at home - https://www.bristolpost.co.uk/news/local-news/firefighter-warning-after-fire-erupts-2659525
edit no smart meter fitted! they have now added the other image of a old style meter. thoughts on cause?
Why have they put photos of 2 different houses (and meter boxes)
up, yet only talk about one fire?
Are you looking a different report to what the OP posted?
The meter box has been ripped out and is on grass covered with dry powder from an extinguisher while the house picture has no meter box in the hole
One of the reasons WPD replace 100A cutout fuses with 80A is because in the case of a sustained overload, the fuse carrier will overheat before the fuse blows in some versions of cutout. Obviously with a smaller fuse, this will rupture before the heat build up occur.
Without more information any suggestions as to cause will just be speculation
Not the pictures I sawon the link in the post.
First picture looked like a box in a rendered wall.
Admittedly it could be powder covered grass.:eek:
Second picture shows hole in a Brick wall with missing box.
I got my specs out - twas the fuse holder lower connection as it seems to be the lowest point and the most damaged. A shear w.a. guess of course :) .
Gavin John Hyde
Patron
Somerset
Website
http://www.sulis-electrical.co.uk
Business Name
Sulis Electrical Services Ltd
interesting electrical fire in Yate nr Bristol
Security Alarms, Door Entry and CCTV (Public)
Gavin John Hyde,
Wilko,
