Interesting three way conversion to two way and swap for time lag. | on ElectriciansForums
Discuss Interesting three way conversion to two way and swap for time lag. in the UK Electrical Forum area at ElectriciansForums.net
T
The Ghost
If your bored or like a challenge I thought (maybe wrongly) this might be interesting to trainees and maybe others. As the title convert three way switching to two way (Sw 2 + 3) [ElectriciansForums.net] Interesting three way conversion to two way and swap for time lag.
danlers time lag (Master and slave) using switch 2 and 3. Assume you cannot find the junction box. Can it be done? Note we have L in at switch 1, no accessible switch return. I included a couple of photos to give the ---- drawing some context. The switch return (green) is pure conjecture on my part, but it must be something along those lines. There is no switch return wire at any switch.
Looks like a standard 2-way to me. Feed in and feed out in the common of Sw1, strappers through intermediate switch and yellow from Sw3 is the SL to the light. If your getting rid of Sw1 you could connect the live through to sw2 and connect the SL and L through in parallel to switch 3. Or am I missing something?
Sorry did not label it but from the photos and diagram you should see the live comes into sw 1 common-to either L1 or L2 on red cables to the intermediate L1 and L2 (Sw 2) correspondingly (all belled out by the way) then from the intermediate top, to the three core R-Y-B two way switch (Sw 3) again belled out from intermediate L1 L2 top to L1 L2 on sw 3 hope that's clear. There is no switch return that I can make out. Or am I missing something?
Bear in mind the junction box is assumed as there is no other way the lights can switch on which they do by the way. I have had no sight of the junction box, could be in the wall joined to old MICC (quite common in this building) or JB in loft 20 foot up with a 2 foot by 2 foot hatch leading to a sargasso sea of cables dust an inch thick and billions of data cables just thrown over the loft and so on.
There are two lights on the stairs. If the yellow cable is the switch return where does the common go to at switch 1 if not the yellow cable at switch 3?
sw 1 common perm live, strippers through to int, other side of int to junction box, strappers connected to sw3 and Yellow from common sw 3 is SL to lights.
Reply to Interesting three way conversion to two way and swap for time lag. in the UK Electrical Forum area at ElectriciansForums.net
