IMO bill Grade D should be the minimum, there is no place for battery or mains only. Interlink is the only way to keep the db levels high in a domestic or HMO, otherwise we sould be fitting sounders in bedrooms to meet the 75db rule. All London and south are now sing from the same hym sheet over the last year or so, main HMO is either grade D or Grade A with the latter having heat detection in rooms and solo mains/battery smoke in same room.
Yup, totally, and we won't fit less than Grade D anywhere.
I'd like to have hoped that all of London was on the same page - sadly not from experience this week alone - two more or less conversions, one in Lewisham, one in Lambeth..... identical down to the plumbing (and refurbed by same contractor) -
Lewisham wanted Grade D throughout, Lambeth (rightly) Grade A due to size. The two buildings are within three Sqm of each other - 230 sq m per floor over five floors! The clue should have been in that for Lewisham's man. He caved when shown the standard.
Also agree totally on dB requirements - and sometimes think part 6 doesn't go far enough at lower grades - especially given a lot of HMOs get filled with more vulnerable members of society. We found variance on that too though - and too many relying on 13.1.2 of part 6 - which claims 75dB(A) will most likely NOT be achieved at the bed head - it's my belief this has moved on a long way since 2004. Typical sound levels even with interlinked stuff (Aico) can still be as low as 45dB(A) at the bed head when siting of the smokes complies with say a D, or a C.
Being totally honest, it's my view that a minimum Grade A should be fitted in any HMO for two reasons - one, residence is transient by nature, and two, landlord often not on premises, hence limited or no responsible person.
- - - Updated - - -
75dB(A) is only a recommendation btw and not enforced at anything under Grade A - again 13.1.2 attests.
