Interlocked switched Socket Outlets | on ElectriciansForums
Discuss Interlocked switched Socket Outlets in the UK Electrical Forum area at ElectriciansForums.net
drzsta
out in the cold
Hi,
Other than ABB, anybody know of a manufacturer that offers auxiliary contacts operated by the switch on industrial socket outlets?
Failing this I'll have to make a panel mounted version.
Cheers.
Have a look at Gewiss. They have a selection of different socket outlets. I know they do socket outlets with electrical interlock with rcd breaker protection ( e.g. part no. GW 66 596).
See if they have what you want.
Reply to Interlocked switched Socket Outlets in the UK Electrical Forum area at ElectriciansForums.net
You actually need to use the light switch since that’s where the lights are controlled from. The red wires should be your travelers going to...
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
