Is there anything more frustrating than an intermittent fault
Discuss Intermittent fault finding in the UK Electrical Forum area at ElectriciansForums.net
I hear you. (I'm an organist btw). I get called in to play for carol services on instruments that barely get played the rest of the year, and real ingenuity can be called for to work around the faults. Tracker (mechanical) action instruments are normally ok, but there's a couple of electro-pneumatics that are long running adversaries of mine. Each year I write a polite essay in the tuning book, and the following year I read the witty responses to last years faults. One year I had to avoid about 6 notes for the whole evening, substituting with right foot and octave coupler.The action of the Compton organ at Southampton Guildhall generates a good selection of intermittents. This mammoth instrument contains about 7,000 electromagnets, over 50,000 sets of contacts and over 100 miles of 26SWG cotton-covered wiring joining it all up. All of the electrical gear, much of which is installed in a dedicated relay room, is original 1937 equipment, almost unique today. The main problem is that it doesn't get used enough, so all those contacts sit there from one month to the next, gathering dust and tarnish (they are mostly silver) and take a few cycles of use to get cleaned and back to reliable operation.
That would have sounded like Les Dawson at his bestOne year I had to avoid about 6 notes for the whole evening,
Foxwell seem to be the manufacturer of choice at the moment. Various models, depending on how much sophistication you want, and how deep your pockets are.Which make of scan I'm looking for a good car one.
Reply to Intermittent fault finding in the UK Electrical Forum area at ElectriciansForums.net
