Intermittent shock at kitchen sink | on ElectriciansForums
Discuss Intermittent shock at kitchen sink in the UK Electrical Forum area at ElectriciansForums.net
vbyrne
Planet Earth
I was called to a job Friday past,the lady of the house and her children are getting shock's from the kitchen sink. First thing I tested was the sink live, no normal. I then tested the earth which is TT and got a reading of 97 ohms I then tested the 10mm earth going to the water stopcock no problems there either. I then tested the three trips that are in the DB 3
30 Ma trips and all disconnecting with in the times . Any body any ideas??
cheers
Is this a rural location by any chance?
No this is in the middle of a town,I was very surprised to see a TT IN THIS LOCATION but there you go. What were you thinking??
I had one once a few years back - tingling at the sink on a TT. It turned out to be an electric fence energiser that was back-feeding through the TT rod!!
I then tested the three trips that are in the DB 3 30 Ma trips and all disconnecting with in the times
Can you elaborate how the DB is configured. From what you have written, I am thinking is this three separate RCDs, or RCBOs in the DB? I presume all circuits are on an RCD, and these are modern RCDs and not some old Voltage Operated device?
Reply to Intermittent shock at kitchen sink in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
