Introductuio & question | on ElectriciansForums
Discuss Introductuio & question in the The Welcome Forum area at ElectriciansForums.net
WS152TS
Hi, Rewired a house around 40 years ago and now helping a friend to rewire another - it will be Part P certified once complete. Have a query re two-way switching. I completely understand what's happening using either the 'conventional' method or the conversion method ... but the latter requires running two cables to one of the switches and the other doesn't. If I'm cabling a two-way circuit from scratch, is there any reason I should use the conversion method? Will I sacrifice some future opportunity to satisfy a requirement that might reasonably arise? I can see that if I have five conductors instead of three at a box I could put in another switch but on that basis I could run many conductors to every box I install. If I'm being dumb, please put me right!!
I always used the (what you call the conversion method) 2 core from the light you are switching and a 3 core between the switches, but with today's methods whereby you feed in and out of the switches, this method can be problematic, I guess it's what ever method suits the wiring methods required in the house, nothing to stop you using either method.
I haven't a Scooby about the terminology, but tend to provide a feed at switches these days, either because customers wanna use those damn smart switches or 'cos its easier to feed luminaires (such as down lights) with the one cable looped to each fitting. And concur about deeper back boxes, 35mm minimum; more room for cables & ventilation (if that's the correct word) and room for dimmer switches.
now can you imagine putting in a 35mm back box in the old ash brick.
because knocking in to one of those babies you are showily will be next door .
Think the old properties won't be an issue, granted some stuff built in the 80's with three sheets of plasterboard might. Have you been squeezing cables into 25mm socket back boxes for a while? :)
Reply to Introductuio & question in the The Welcome Forum area at ElectriciansForums.net
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
Definitely, although most likely within the accessories. I've often found that once accessories are disconnected the cabling IR is fine. Sometimes...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
