Intruder alarm | on ElectriciansForums
Discuss Intruder alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Lou7
I know its the wrong forum but does anyone know about intruder alarms, i'm replacing my old knackered panel with a new version but different terminations.
need more info. old panel type? new panel type?
Old = Scantronic 9200 series
New = Optima Compact Gen4Old one had separate Entry Exit terminals, new has 8 zones does it matter which zone I use or does that all happen in the set up.
I remember the original engineer added a reset button on top of panel, that I press before setting, new one doesn't have one.
old bell terms - Trig +, Trig -, OV, TR
New bell terms T,A,D,B
[ElectriciansForums.net] Intruder alarm
A and T are 0V and TR. B and D are +12v and trig -. not sure which way round, but think they are marked. use zone 1 for entry/exit.
Wire all zones the same, zone 1 is entry/exit.....all zone tampers will now have to be wired in series, and terminated in 24hr terminals.
Any zones not used, leave wire link inplace. E/T button wiring if use, not connected.
Aux + - , are the same for powering pirs,
Bell wiring of 9800 to ADE = Trig + wire to D...Trig - wire to B...ov wire to A....TR wire to T
Hope this helps
Thanks Tazz
I sussed out the tamper loop. I'm not sure if I need the reset button, I think it was to reset the indicator lamps on the vipers.
I only have door contacts and Vipers no PIR's.
I don't have a remote keypad on my system but it looks like i'll need one for programming.
The ade panel has an auto reset for vipers which is SET terminal......the 9800 reset switch fitted, i guess would go to + aux and to latch terminal on the viper. The latch terminal wire of the viper, can now wired to the ADE set terminal. On silencing the panel, the zone and viper led will stay lite, showing which viper activated, on full panel reset, all vipers and the panel will reset automatically.
On existing panel, wire from Aux to N/C button then to bunch of Red wires. So I can put the bunch into the SET terminal ? At the moment i've put them in +13v
think the button might be to drop the 12V supply to the vipers to reset them. check with a meter if it push to break ( i.e. goes open when pressed ) then it probably is.
Reply to Intruder alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
Hi. I have a wired Optima alarm. Due to wiring access issues, I need to add a wireless door sensor. Sometime back, I recall seeing a product that...
