Intruder alarms | on ElectriciansForums
Discuss Intruder alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
spurs21
Just wondered what the pro's and con's are of wireless and hard wired alarm systems.
Do some insurances state alarms must be hard wired?
Wireless you will have batteries to change. You have the nightmare/easy task of pairing up all the pirs.
Wired physical connection, easier to setup (once wiring in place) no batteries to change.
Depends on your insurance they will normally specify a "cat" not if its wired or wireless.
Reply to Intruder alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
D is the negative for the SAB hold off supply In the bell the 0v is linked to one side of the tamper switch and then the other side goes back to C...
problem is, with cameras that upload to the cloud, they only upload motion detection or small video clips. when you want continuous connection the...
