Inventor Required ... | Page 2 | on ElectriciansForums
Discuss Inventor Required ... in the Australia area at ElectriciansForums.net
acvc
Ulan Bator, Ulaanbaatar, Mongolia, Mongolia
Could someone please get their finger out and invent an earth sleeving dispenser that works like a small tape measure - you pull out the length of sleeving you want and press the button to cut it?
I'm a bit busy at the moment ......:D
But it would be good wouldn't it?!
It is made here, SY cable has the cpc sheathed,so they could easily make some without the sy bit. (assuming of course that SY is made in this country). - I used a lot of it in vermin infested lofts- regs say has been or likely to be infested - this i now believe to be not exactly a requirement, but snags and solutions give it as an answer to rts and mice. I love them. From a discussion once its unsheathed to allow for the fact that if one of the line conductors is damaged, then if the cpc is unsheathed then its more likely to throw a wobbly down the cpc if its in ready contact with it, i.e. unsheathed. Would make for a thicker cable though, some re- wires are tight enough as it is !!
Does any one know how they made the old lead wiring ? I cant see a seam in the bit I have liberated , and the rubber insulation inside around the conductors would of melted if there had been any heat involved, sad but just something i always wondered about !!
Reply to Inventor Required ... in the Australia area at ElectriciansForums.net
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
Your biggest mistake is admitting to a mistake.... If theres no witnesses, it didn't happen. However.... A few golden rules.... Never trust...
