R
rb1
Anyone on here had to alter the language settings from german to english on sma inverters?
Help would be most appreciated
You will find three dials on HF and TL inverters. From left to right you need to set them to '5', '8' and '2'. This will put you in G83 mode.
On the 4000TL, the 3rd dial (RHS) is used for setting the bluetooth ID as far as I am aware - it needs to be set between 2 and F to enable the bluetooth. It says 1 inthe book but that is incorrect.
Cheers
Dave
Reply to the thread, titled "Inverter help" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
