View the thread, titled "Shelly app to garage motor unit wiring" which is posted in Security Alarms, Door Entry and CCTV (Public) on Electricians Forums.
Hi guys,
I’m really lost and need a bit of a hand with the I wiring of this Shelly wifi relay switch to the door motor?
The client wants to be able to control the door using this Shelly relay switch which potently gets connected into the little unit - see photo.
So the client will download a app and then be able to control the door from anywhere in the world - wifi dependant on course.
If anyone knows/has experience with these Shelly units and this door motor - just as the pictures aren’t great
We have the feed on the left - LIVE, NEUTRAL EARTH
and
Right flex is the following
  • Live
  • R -??
  • Earth
  • Neutral
Any help would be amazing!!
TL;DR
I think L and R might refer to left and right, meaning the direction of rotation of the motor.
I have one roller door here with the motor built into the spool, which is controlled by a simple spring return to centre three position rotary switch. IIRC, neutral is unswitched, and the rotary switch applies live to either L or R.
Reply to the thread, titled "Shelly app to garage motor unit wiring" which is posted in Security Alarms, Door Entry and CCTV (Public) on Electricians Forums.
L/Spa
Reese Sangha,
brianmoooore,
