M
moggy1968
have sent you the user manual. if you need anything else just let me know.
YOZ - I've not used the 3000Tl, tend to use the 3000HF but unless there is a need for an RCD under 17th ed there is no need for an RCD, on this or the 4000TL. I don't think 2 strings would be needed. Why did you think it would be? I haven't checked the inverter stats but would have thought input voltage would be fine on a single string.
4mm cable is fine unless the AC run is long (over about 20m. if it's close to that let me know and I'll do the actual calcs). I'm pretty sure the manual says you can also use 4mm on the 4000TL dependent on the length of the run, but it doesn't give you much length.
The original poster is the customer and they've got what they've been supplied with, a 3000TL
