Inverting old planer jointer motor | on ElectriciansForums
Discuss Inverting old planer jointer motor in the Electrician Talk | All Countries area at ElectriciansForums.net
France
Hello everyone,
I've come across an old but trusty planer jointer with an old motor on it. But the way I want to re-assemble the machine makes it so I have to invert the rotation for the motor. I've tried a few things I've read but I probably messed up as it only resulted in poor speed and slow start-up (and huge power draw, so the capacitor may have been bypassed) despite finally going in the right direction. So for now I've rewired the terminal box as it used to be and the motor is fast and torqy again (but of course rotating in the opposite direction I want)
Here's the motor plate, it's a monophase 220v from the 80s with a big capacitor
[ElectriciansForums.net] Inverting old planer jointer motor
here's how the terminal box is arranged :
Could you help me rewire this bad boy so it works well in the opposite direction ?
Thanks a lot !
TL;DR
Need to invert rotation of old motor by rewiring the terminal box, can you guys help ? diagram included
Do you have a test meter of any kind?
if so, disconnect all four wires that go into the motor and check for a low resistance between them. You should find a low resistance between two of them, a low resistance between the other pair and infinite resistance between the two pairs.
Reconnect the wires, but swap over one of the pairs.
Beware of touching the capacitor connections if power has been applied to this motor recently. They can bite.
Reply to Inverting old planer jointer motor in the Electrician Talk | All Countries area at ElectriciansForums.net
I posted a month ago regarding a single phase motor + panel I have been given to try and sort following water damage to the panel. The assembly...
Hi The first idea is that there might be a conflict in the connections of the fans. However, since the issue been seen in a fresh air chambers...
This isn't a start-stop type. The motor just runs (while switched on) and it has a flow sensitive unloader valve. So with trigger valve closed...
Youre in the same boat as me. I was previously with niceic and later on, napit. No issues. I didn't bother finishing my nvq3 as in 2010 during the...
Hello and Happy New Year. It's not starting too well for me, excuse pun. Since Friday December 16th, The 2.4l Duratorq diesel won't start...
