Investigation on massive electricity bills | Page 3 | on ElectriciansForums
Discuss Investigation on massive electricity bills in the UK Electrical Forum area at ElectriciansForums.net
Andover
Hi all,
This morning I visited a new client who needs me to find out why there bills are so high.
At the moment I can only give a quick rundown of the installation as it was just a general chit chat about the issue. I will be going back to do some proper investigation in a week or so.
This is an old manor farm with the main house having been extended along with an attached barn conversion which is their main living space. 3 story's including the loft conversion so quite a considerable space. They have a 3 bed cottage ( Detached )on the land along with stables a plant room and a wooden barn converted for parties in an L shape. So they called me because they are getting extremely high bills. The 2 that I saw was 1 for last 3 months and 1 for the previous 3 months. The latter was for ÂŁ4100 and the other was ÂŁ2700. I did get a quick look at a couple others and they were similar costs ranging anywhere in between.
Firstly can anyone say whether this is normal for a house of this size when they have assured me that they don't use the emersion heaters as they have 2 big oil boilers in the plant room.
Wet underfloor in the new half and the barn end and radiators in the old part of the house.
Also my first thoughts are that I need to familiarise myself with the wiring of the entire installation so I can eliminate circuits one by one. Any advice is welcome as always.
Thinking may get away with a clamp meter as I've just seen the price of these machines. Just check current flows to each DB and see which one has got an unusually high current flow.
That will only tell you the instantaneous current flow, it won't tell you anything about the average demand.
I would say the first thing to do is contact their electricity supplier (the meter operator, not the DNO)
I believe they are required to investigate if there is a query about the bill.
As mentioned above if the bulls are estimate s this may be part of the cause. Have a look at previous bills to see if there is a gradual increase over the years or if this is a sudden jump up.
The expense of a data logger at this stage seems a little excessive, a basic clap meter will allow you to identify the circuit (s) with high loadings. If you can't identify an issue with this method then a data logger might be considered a robust method of demonstrating a meter malfunction to the DNO.
However, Do DNOs offer meter calibration testing - only charging the customer if no fault is detected.
Let us know how you get on.
I bought myself the Fluke 1730 Energy logger and it's already paid for itself at nearly 2k it wasn't a knee jerk purchase but I've had it hired out nearly every week since I bought it so it is now making money every week.
They are well worth the money, simply input the unit price for electricity and it will work out exactly what your installation is costing.
The logging period can be set from 10 minutes to 3 months and at the end you can print off the results or email them direct to your customer, equally you can drag snapshots off of it with a memory stick while it is logging.
We also use it to carry out load tests on machinery, some of our customers like to know what some of their large machines are costing to run for help with working out production costs.
Problem with such vague posts such as these as we are all guessing.
OP - you need to ask the customer to get out ALL their old bills, and
1. look at the amounts due
2. they need to check if they are estimated or proper readings
3. also log the consumption per quarter
- only then can they actually compare apples with apples.
with that amount of current flowing it shouldn't be hard to find.
Indeed not. If half the bill is wastage via leakage to earth, the L-E insulation resistance would be 8.2 ohms, so about a ten-millionth of what you might expect on a domestic system. You would want to search for it with a continuity tester, not an insulation tester, as that would just read a string of zeroes - 0.000008 Megohms if it had that many digits. Somehow I doubt this as the cause - the fault would be dissipating the heat of over three 2-bar fires, which I can't imagine XLPE SWA withstanding for over six months. The ground would probably be steaming! Although anything is possible until you get some data.
may be the electricity company they get
the supply from need to be involved and ask them.
Think this is the most sensible suggestion to check first. Why pay hundreds of pounds getting an electrician to check if there is something wrong with the electrical installation, if they've got some dodgy meters or readings.
Get the fuel supplier to verify their meters.
And if the readings are correct?
well you can do some very simply thing like check the electrical meter readings on a daily basis, record these and see if there is a spike, you could do this over the Phone with the customer
then see what they are paying for a KW hour, normal about 13p. ish but it may be cheaper.
but if the customer are well off then look at the energy tracking devices which are out there a couple of hundred quid. these are better as they will record the power consumption and give you an idea if its a steady consumption or a spike at a certain point. These can visual display the Data in graph form for easy of understanding.
if its a steady consumption then get a clamp meter out and check all the circuit to see whats going on and which circuit is using the power.
hope that helps. goggle is a good tool
here a web site which offer some tracking
Tracking Your Energy Use | Home Power Magazine - https://www.homepower.com/articles/home-efficiency/electricity/tracking-your-energy-use
your need to find a 3 phase meter,
I think ÂŁ4100 is quite a bit, A very rough calculation, if they paying 13p a KW hour ,
then they using something like 31,538 KW Hours ,now if that's a quarter then there about 11,500KW hour a month and about 350KW hours a day. that mean they are using 14KW every hour.!
Reply to Investigation on massive electricity bills in the UK Electrical Forum area at ElectriciansForums.net
