IP rated switchcover | Page 2 | on ElectriciansForums
Discuss IP rated switchcover in the Electrical Tools and Products area at ElectriciansForums.net
When you say the switch is failing I take it you don't just mean the metal is tarnishing?
No some of the buttons are not functioning. We have many others in suitable environments, that are still working ok. Its either the swimming pool environment, or we have just been unlucky. This one, the faceplate fell off, the push in contact fixings failed (the welds failed). My money is on the wet, warm chlorine air, doing the damage.
Then IMO the unit needs relocating even with one of those covers it's not going to be airtight and whilst it will slow the degrading down it will not prevent it continuing.
Yep I know, going back to my OP. Relocating is not an easy option, something which might have to happen.
Reply to IP rated switchcover in the Electrical Tools and Products area at ElectriciansForums.net
The contacts are pushed open by a cam as the shaft is turned so they operate quite slowly. That's fine on AC as any arc is self-extinguishing at...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
