M
msec
Hello all,
I've just carried out the remedial works from a EICR on a small industrial unit ( I didn't carry out the EICR). The 3 phase board had tails entering through seperate holes on the bottom, which was coded as a 2 due to possible eddy currents. I remedied this by cutting out the gap between two of the holes and feeding all the tails through the bigger hole, to which I fitted a grommet strip. I installed blind bushes and locknuts in the two remaining holes.
Based on the advice of an 'electrician relative', the manager has now questioned the suitablity of the new hole, saying it does not comply. My understanding is the top & sides of the board must be IP 4X (not be able to be penetrated by an item 1mm wide and 100mm long) and IP 2X on the underside (that you must not be able to penetrate with your finger, which you can't, not even a small amount).
Can anyone please point me to the relevant regs regarding this, as I seem to be struggling to find anything clear.
