Ip44 230v zone 1?! | Page 2 | on ElectriciansForums
Discuss Ip44 230v zone 1?! in the Lighting Forum area at ElectriciansForums.net
Can we see this fitting and where are you installing it.
I want to put it above my shower its a small shower room so the tray takes up most of the room...
From the tray to the ceiling it measures about 2.15m so the light would be just above the shower head
But from the floor to the ceiling it measures 2.4m there is a massive step into the shower
  • [ElectriciansForums.net] Ip44 230v zone 1?!
It does suprise me that a room containing a bath/shower isn't IP66 /IPX6 as minimum, purely based on the fact you can fill a cupped hand with water and throw it at the ceiling/light fitting, same with a showerhead (unless fixed spraying vertically down - Just with improved accuracy thanks to the Jetstream)
If you throw a cupped hand of water at an IPX4 rating fitting it should be protected. This rating is for splashing of liquid from any direction.
You said you would use a higher ip rated fitting but the ip44 fitting complies?
Its hard to find ipx5 or 6 or 7 lights i have been looking for ages :/
Water jets as in above a shower but still in zone 1
This is mainly aimed at water jets used for washing and cleaning that are not from a fixed source, so a standard shower head pointing downwards would not apply.
If you had one of those fancy showers with several wall mounted heads that automatically rotate and spray water everywhere, much like an automatic car wash, then you would need a better IP rating.
Although the zones do have a height limitation there's the application of common sense, what's the likelihood that the fitting will come into contact with water and in what amount? In the vast majority of applications IP44 is more than acceptable, BS7671 gives us the minimum rating to work to.
Reply to Ip44 230v zone 1?! in the Lighting Forum area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
Thank you..... & did have all the fan isolator/ fuse in same plate (click) so quinetic wouldn't worked on this occasion
