IR reading | on ElectriciansForums
Discuss IR reading in the UK Electrical Forum area at ElectriciansForums.net
West Lancashire
I was called to a tripped rcbo on a lighting circuit. Using my megger 1721 I checked continuity between N and E but noticed an induced voltage of around 15V. Same across L and E. When I did IR checks the readings fluctuated between 1 and 90M and eventually the meter showed ‘Error’ and had to be recycled to work again. Put it all back together and it stayed on. Went away an hour later was called to say it tripped again.
Reply to IR reading in the UK Electrical Forum area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
