IR test on lighting circuits | Page 2 | on ElectriciansForums
Discuss IR test on lighting circuits in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
The proformers are generally designed to be over complicated and get you to do unnecessary tests.. Notice that there is no mention of measuring the MPB but you might be expected to measure R1 and R2 of a final circuit which is unnecessary as you will check it when loop testing.
The best test instruments for basic anomalies are your eyes, ears, nose and touch..
How are you proving R1 +R2 100% when you are doing a loop test?
Reply to IR test on lighting circuits in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
Not all sockets isolate both the live and neutral when you turn the switch off Many just isolate the live leaving the N connected. So the...
