IR test with transformers and dimmer on circuit | Page 2 | on ElectriciansForums
Discuss IR test with transformers and dimmer on circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Very true about logic of sometimes wiring to switches but here I really can't see what they was thinking it's a wooden plinth box cut into and can only get depth of shallow back box really with size of dimmer really is hard work getting all conductors at back of box
Yeah 35mm or deeper is sometimes required especially if you've got an in and out mains and a switch wire.
Reply to IR test with transformers and dimmer on circuit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
When I was at college doing the 2361 back in the 1980's I still recall to this day the instructor (Mr Wood) saying "Lads I do not want you to...
Very technical :D
