Hi lads, Just want to pick your brains . When you do an IR test and you cant disconnect current using equipment for what ever reason, the regs say you can connect line & neutral together and test to earth. Where would you put the result in on the test sheet? Line/Line or Line/Earth, and do you leave the other blank? Only when I worked for a company testing re-wires and I could not dissconect current using equipment, I did this test and they still wanted me to put a result in both box's. Any comments would be great.
