irish electrician s | on ElectriciansForums
Discuss irish electrician s in the UK Electrical Forum area at ElectriciansForums.net
Firstly I would like to apologise to any Irish Sparky on the forum, but because of all the jokes many years ago when someone says Irish Electrician I can't help but think Plumber!! :)
Irish trained sparks are trained to as high or higher standard than the U.K.No 5 week wonders over her my friend.You're a time served spark or you are not....
Reply to irish electrician s in the UK Electrical Forum area at ElectriciansForums.net
I just don't get it, in the UK if you connect the earth rod installation to the neutral of an overhead TT system then you create a problem that is...
This isn't at all unusual. Companies often use subbies and as such are just essentially paying for their services resulting in little or no...
