Is a 2 pole breaker the same as a breaker that has twin single poles? | on ElectriciansForums
Discuss Is a 2 pole breaker the same as a breaker that has twin single poles? in the USA Electrical Forum area at ElectriciansForums.net
Muffie1234$
I am searching for an RV 30/20 amp 2 pole breaker.
(Cutler-Hammer BD3020 A3020 Types BRD, & A 120/240V Cu/Ai HACR Type 2 pole unit J-969
E7819 - T LR43556 Disj)
I see quite a few breakers with these specs.....except they are 1 pole.
I have seen breakers that are twin single pole breakers and was wondering if they are the same as a 2 pole.
Thanks, Rc
  • [ElectriciansForums.net] Is a 2 pole breaker the same as a breaker that has twin single poles?
Thanks, Rc
A 2 pole breaker will have a bar between the 2 breakers and the slim line breakers that you are referring to are just 2-15 or 20 amp single pole breakers. Home Depot or Lowes sells Eaton type BR breakers. Good luck and welcome to the forum
Reply to Is a 2 pole breaker the same as a breaker that has twin single poles? in the USA Electrical Forum area at ElectriciansForums.net
By code the washing machine needs its own 20 amp single pole GFCI circuit, the dryer needs a 30 amp double pole breaker and using # 10 wire. Your...
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
