Is EIC required for this job (New CU & ring main) Electrician says no? | on ElectriciansForums
Discuss Is EIC required for this job (New CU & ring main) Electrician says no? in the UK Electrical Forum area at ElectriciansForums.net
Artoo
Cheshire UK
Hi, I've contacted an electrician to install a new consumer unit, as well as a new ring main into the loft. I asked if his quote included the appropriate certification, I assume an EIC, he said "as far as certification is concerned you don't need any as it's straight replacements", I checked my local council building control regs which state that "notifiable works include a) The installation of a new circuit; b) The replacement of a consumer unit"
So is he trying to save me £480 by not making a building regs application for a £100 consumer unit? Or is he cutting corners and I should look for someone else? He appears to be legit, positive reviews on Ratedpeople and accredited by NAPIT. Could you guys advise, I don't know enough about certification to call him out on this but I don't want a cowboy job that I'll regret later..
Can anyone help?
Rated people, ignore this bloke, like Murdoch said get some quotes from proper Electricians, rated people. rated Chancer's would be a better description, imo.
The reason electricians register with a competent person scheme like the NICEIC, Elecsa, Napit, Stroma etc is so they don't have to pay the extortionate building control fees for notification. Find yourself an electrician who's registered with one of these schemes and get them to quote.
The reason electricians register with a components person scheme like the NICEIC, Elecsa, Napit, Stroma etc is so they don't have to pay the extortionate building control fees for notification. Find yourself an electrician who's registered with one of these schemes and get them to quote.
components persons schemes they can't be very component can they?
T
That's the thing, he is registered with NAPIT so I don't see why it would be an issue for him to provide the certificate. I've emailed him the building regs and questioned his assertion, but I think probably better to find someone else who isn't so cagey about certification to do the job! Thanks for the quick replies.
He actually wrote that in the email when I responded to his initial quote, which is what led me to investigate further!
ooooooo... cool. email it to NAPIT, with the electricians name and see what they say.
Reply to Is EIC required for this job (New CU & ring main) Electrician says no? in the UK Electrical Forum area at ElectriciansForums.net
Pretty common for lights and sockets to get a Re-wire and the Eco7 circuits usually storage heaters /water heater to remain left as was. As for...
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
