is it a regulation to cross bond the heating pipes under the boiler? | Page 2 | on ElectriciansForums
Discuss is it a regulation to cross bond the heating pipes under the boiler? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I still do it because it is often quicker to do, looks really nice, and i get zero didcussions about bonding pipework with anyone on site
This subject is probably one of the most confusing issues known to man in our electrical world. It is very well explained in the BGB. You must if.............and it is not necessary if..............................and you can do it there if you please.
Cheers...........Howard
You still need to meet the above criteria. Which yes a lot of 17th circuits do.
As for trusting a plumber........
I think there should be a regulation on that LOL
I can just see it in the regs, before anything else on page 1. Regulation 000. Thou shalt disregard the evil spoutings of thy heating installer for verily he is nay more than a spark with no brains and he will lead you from the path of righteousness and adherence to the regs. Yea verily Sparkys are God's chosen tradesmen
under the 15th, everything was bonded,, it was stupid,, even the metal crital window frames.. the 16th did away with that.. and the 17th have at last seen even more sence. so no. you dont need to.. but gas safe may still be lagging behind
So if there seeing more and more sense. Maybe trev's regulation will be there for 18th.......
LOL
As far as am aware Gas Safe dropped the bonding issues also. I used to do a lot following CP12s but it's no longer mentioned. Currently doing my gas qualification too and only the main equipotential bond is ever mention no supp bonding
Reply to is it a regulation to cross bond the heating pipes under the boiler? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
New Boiler Being Fitted; heat only or combi boiler? I am having a new gas boiler fitted for central heating only. The pump needs to be part of...
Alan Wright
A
M
One pipe system condensing boiler. Would a one pipe system work efficiently on a condensing boiler as the return type would likely be below 54c...
Matt0029
M
