Dantheman
is it ok and within the regulations to earht a gas meter by using a earth rod and taking a 10mm earth from the rod beside the meter to the pipe?
(on a PME)
(on a PME)
Discuss Is it aceptable to earht a gas meter using a earth rod?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
(on a PME)
(on a PME)
Just use an RCD, no need to run them ugly green/yellow cables anywhere!Anyway.... Why would you ever earth an incoming service......LOL
Reply to Is it aceptable to earht a gas meter using a earth rod?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
