Is it ok to run cable within a boxed vent pipe? | on ElectriciansForums
Discuss Is it ok to run cable within a boxed vent pipe? in the UK Electrical Forum area at ElectriciansForums.net
M
magicstu
I may get my head bitten off for this, but please be nice. I want to get the supply to my cooker replaced from 6mm to 10mm, but the existing route is almost impossible, but there is an easier route following the vent/stench pipe (that is boxed in ) through the bathroom and into the loft, then across to the front of the house and back down to the consumer unit. One company said they cant do it, as it passes through the bathroom, another has said it's ok because the cable is not part of the bathroom, and the boxed corner is completely built into the wall, I want to run the cable myself and get the electrician to do the final burying of the cable in the kitchen wall for the last 1.5 metres, and the final installation at the consumer unit with a new breaker, neither have an issue with that, its just the cable running down the boxed in pipework- Can anyone tell me if there are any regulations that it breaches? Thanks
Just a quickie from me cos I'm going out.
I don't see a problem with the cable sharing the space with the stink pipe inside the boxing, but we are not supposed to let cables dangle with out being supported.
If you could remove the boxing and maybe cable tie the cable to the pipe or clip it to the wall at intervals of say 2 feet then refit the boxing it would be acceptable.
Surely the electrician that is going to be making the final connections can tell you ?
That's why I was asking, one electrician said it's ok, the other said it's not, but only because it passed through the bathroom. I thought it would be wise to get the opinion of a lot more people to find out.
Would the company that said No, not run cables over the bathroom ceiling as "It's also part of the bathroom".
The cable will have to have protection appropriate for a buried / concealed cable of unknown depth.
Well, as you have already said, you are going to have to choose an electrician that you trust anyway and he is going to have to run the cable where he sees fit, so that he can connect the circuit and sign it off.
I'm sure you can understand that when someone tells us that "they will get an electrician in later", it normally means that they are planning to do the job themselves and want to know how.
My advice is...
A) Find an electrician you trust
B) Let him/her do the job
My advice is...
oh, you cynic Guitarist!
point is ... why???? i'll bet that the cooker don'y need more than a 6mm cable on a 40A MCB ( if cable installed method C ) or a 32A if derating factors apply, unless 50% of cable is buried in insulation.
Since your electrician will be installing the cable to the current regulations there will not be a problem passing the cable through the bathroom, it would only be if the installer was not meeting the current regulations for installing a new circuit that this would be a problem.
Oh and I agree with the others; 10mm is not required.
There are domestic cookers out there which require 10mm 50A supplies.
Wolf sprins to mind as one manufacturer, their big range cookers will draw 50A on their self cleaning cycle!
We got caught out by this once when I was an apprentice
Reply to Is it ok to run cable within a boxed vent pipe? in the UK Electrical Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
