This PV system output performance is outstanding, the solar panel power is 3.52KW, but peak output power is above 4KW, how is this possible?
Stoke Hammond G7PKF 3.520kW
Discuss Is it possible? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
FB do you have your system listed on pvoutput.
It's probably being uploaded vi a Current Cost monitoring system!!
Seriuosly though the question is: What is monitoring the output / how is it being uploaded.
We have found the CC systems to be out by 20 - 50% -OK for RELATIVE information, inaccurate for real monitoring.
somthing does not add up here.
421 kwh our 4 kwp did in south coast in august!!
This is another system ,I have been watching which batters my system by about 25%
Other than a cooling breeze, Are there any advantages from being on the coast?
Coastal areas, and low-lying areas in general - tend to see a little more sunshine and a little less rainfall than more inland or higher land.
Plus you've got the cooling breeze, but on the other hand in winter the sea will buffer the worst of the cold.
But your 484kWh from 3.84kWp (126kWh per kWp) is very similar to my 465kWh from 3.75kWp (124kWh per kWp), so yet again it casts doubt on the figures from the system which belongs to the opening poster.
Where did you get 484 from?
Reply to Is it possible? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
