This thread titled "Is it possible?" is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
???? On my"your output" page,the figure is 573
How interesting. I was not logged in and got those numbers.
After loggin in, I can see the 573 for your system, and mine now shows as 551. But I'm now wondering whether that's the target generation for the period ahead, and that we've both generated about 4-5% of the month's target.
I've now gone into "statistics" and found that you generated 445.7 in August (425.3 for me).
442 v 418 in July.
417 v 409 in June.
1305kWh v 1252kWh in the last three months.
1305kWh/3.84kWp = 340kWh per kWp for the three month period from your system.
1252kWh/3.75kWp = 334kWh per kWp for the three month period from my system.
Difference: 2% in your favour.
Wouldn't bother worrying about anything that is obviously out performing everything else on pvoutput as you have absolutely no way of knowing how the data is being read and input. Can't figure out why anyone would want to, other than to just mess with people for some demented reason, but it's perfectly easy to just make it up on pvoutput. I know I have to put mine in by hand as I haven't figured out how to get it out of my solaredge inverter automatically yet. If you know yours is accurate then don't lose sleep over what others are doing as they are only cheating themselves.
im not sure it was possible to produce 535kw for july and 561kw for august after the dreadful summer we had maybe spain but not hear i wonder what equipment was used to take readings but it doesnt look right to me. mine noshadejoe 3.900kW are miles away but my climate is something different again but is taking from the optismart and is spot on with the generation meter
442 v 418 in July.
417 v 409 in June.
If you float the curser over the figure is says-
total generation and consumption for the period shown.
I haven't added it up but I therefore assume it is a total of the page below
437kWh in August for my mate in York who's system I installed at the end of july. Slightly east of due south.
4kWp Yingli Panda system with SMA 3.6TL
Yes I agree moggy I thought I was doing well with 463kWh in August but that is a whole 100kWh more. If it's true I would love to know how.
the only possible explanation i can think of it might be on a tracker which would make a difference
Reply to the thread, titled "Is it possible?" which is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
