is it worth it?? | on ElectriciansForums
Discuss is it worth it?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
m4fiaafg
basically a very good mate who is an electrician has done a job and wants me to issue a completion certificate. i had a look a the fuse board it had 4 lighting cables in the same breaker etc etc plus 3 in the ring circuit. although everything in each breaker was on the same circuit he sais there no problem and its perfectly allowed. what would you do
cheers, any advise will brilliant
The fact that you have posted on here for advice,shows that you are not really happy with what he has done,would you jam 4 circuits into 1 circuit breaker,i expect not,you know better.make your excuses i think,too busy.....or abroad even better
not a chance i got told by a lecturer once the cell door is always waiting for you when things go wrong and the only way of making sure its not your name above it is by not signing anyone but your own name on the certs
Reply to is it worth it?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
