Is my installation according to the 17th Ed.? | on ElectriciansForums
Discuss Is my installation according to the 17th Ed.? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
JamesMichaelson
Just would appreciate any help, just finished my first electrical installation of the day?
I'm having a little trouble understanding the 17th Edition regulations. Do you think my job is OK?
[ElectriciansForums.net] Is my installation according to the 17th Ed.?
Have you any photo of how cable are isolated I seen open knife isolator, that would look good in a 1920 horror movie, I love the IP rating either plastic bag or sheeting nailed to pole covering electrics.
All houses in Vietnam have a voltage regulator indoors, the usual consumer unit (metal clad)
with a 100 amp main swithch & MCB'S, no RCD's & no earthing,
they still use cloth coated single cables & Clipsal fitting are common,
it's the electrical supply to the house I worry about as you can see from the picture posted above :eek:
Reply to Is my installation according to the 17th Ed.? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks mate for the advice, this is just what I was looking for. I think I’ll have to put some thought into the domestic route due to the NVQ and...
A day for sure. I recently installed an Anderson with dedicated CU. The run was a fair bit worse as I had to drop a section of ceiling and chop...
