Is there a protective cover for the 'BACK' of a dry lining box? | on ElectriciansForums
Discuss Is there a protective cover for the 'BACK' of a dry lining box? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Hello all..
I have been asked by a customer to fit a recessed socket in the kitchen. The socket will be located on the side of a cupboard (no other viable options). I have given them options of nice looking wooden surface boxes but they are adamant they want it recessed.
I want to cover the back of the dry lining box with something as it will be accessible once the cupboard is opened and I think the box is designed to be hidden in a cavity.
I could easily make a wooden box thats fits over it inside the cupboard and screws into place (still an hours work) but I wondered if there was an actual product for this or if anyone has any better ideas for making it safe?
Cheers..
Here you go:
[ElectriciansForums.net] Is there a protective cover for the 'BACK' of a dry lining box?
Chuck the lid away and secure the container in place with trusty Gaffer Tape (the Roadie's best friend)
Here you go:
we know olive spreads, but does popeye know?
use a surface box in cupboard. should get away with a 16mm one once taking the thickness of the chipboard into account.
I had thought of that Tel but just assumed it wouldn't be big enough! I'll have a practise when i get home.. cheers!
... Just thought , do you mean 'Just' a surface box (inside cupboard) instead of a dry ling box?
yeah. a surface box. cut the cupboard hole just undersized for the box, then sandwich box/chipboard/socket front
Hello all..
Cheers..
I wouldn't do the job, the cabling is going to be at risk if it is in a used cupboard and especially if the box needs a cover because it will be visible, a bodge job, a matter of time before a saucepan gets shoved against the wiring, abandon ship man overboard.
What Tel said.
I think he means the surface patress goes one side of the chipboard, the socket front goes on the other side of the chipboard.
The hole cut in the chipboard is slightly undersized so as to allow it to be trapped between the socket and back box.
I think that is what he means, and it's a really good idea.
Oh dear, the job is now turning into a fire proof box, quite an eyeful for the customer I suspect, Get an electrician to explain it is not acceptable and look at other options.
Why are you so set against putting a socket in a cupboard, surely this happens all the time, and they just use standard accessories which aren't fireproof?
I'm confused why this is such an issue when it's only a variation on a standard surface mounted setup, or have I misunderstood something the the OP and the replies?
Reply to Is there a protective cover for the 'BACK' of a dry lining box? in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
An example of the long term race to the bottom of quality of work in our industry, IMHO.
