Of all the things you can't buy in the States an incandescent lamp, how ironic.
Discuss Is there a way to move around a drilled hole in ceiling without drilling another one in the DIY Electrical Advice area at ElectriciansForums.net
As we all know there will be nothing but LED in the years to comeOf all the things you can't buy in the States an incandescent lamp, how ironic.
I think you miss my point.As we all know there will be nothing but LED in the years to come
It is in developmentLED is just another step in the lighting story.
Something else will be along in the future to replace it.
Don't ask me what as I dont' know, but I wouldn't be suprised if it's already under development.
https://www.neutechnik-toolshop.com/products/drill-hole-moverIronic, maybe...but I won't be phoning Alannis anytime soon.
Seriously, what's the harm in drilling a wee hole, putting a rawlplug in, and filling the old one with a bit of filler?
Or am I missing the point entirely?
Are you saying that your ceiling is concrete?Sorry for the confusion! That light bulb and the fitting is a temporary one. This is what the back of the light I want to put looks like:
So effectively I need 2 suspended screws that distance apart. I am going to get rid of the existing fitting and bulb.
As suggested by the other members, I might eventually end up drilling a hole if nothing works out, but I want to avoid it if I can - mostly because my previous (first) attempt at drilling concrete was disaster.
Thank you everyone for the pointers!
Cut a strip of the ceiling off the width of the distance you want to move the hole. Then slide the whole ceiling across. Job doneHello everyone!
Is there a way to move a drilled hole in ceiling slightly to the right without drilling another hole. I need to suspend a light ceiling lamp and want to avoid drilling another hole if possible. I am imagining something like this:
So effectively I am looking for a flat horizontal strip which has support to put in screws anywhere. Is there something like that which already exists? If yes can you please share a link/name? I tried looking but was unable to find anything. The lamp is very light and there won't be any stability issues.
Thanks a lot!
Reply to Is there a way to move around a drilled hole in ceiling without drilling another one in the DIY Electrical Advice area at ElectriciansForums.net
