C
cadspark
Is this a 2 phase supply in this picture? The two 25mm tails connect into a 3 phase switch fuse unit into just 2 of the fuses. SWA is run from this unit to a seperate building housing a water heater for an outdoor swimming pool. The heater is on a 3 pole circuit breaker with the swa connected to 2 of the poles and these both bridge accross to the 3 pole. The 3 pole output is then combined in a henley block and taken to the heater in 25mm tail.
