Is this meter installation ok? | on ElectriciansForums
Guest viewing is limited
Discuss Is this meter installation ok? in the UK Electrical Forum area at ElectriciansForums.net
Scotland
Hey guys, just wondering if this installation is ok? the neutral can get isolated on the main circuit which if the second circuit is not isolated would mean there is no return for the second circuit. the isolator switches are individual, each iso switch switches the L and N at the same time (its actually two isolators in one shell)
[ElectriciansForums.net] Is this meter installation ok?
If things are as your diagram, then all is well, but your text throws doubt on whether it really is a four pole isolator.
It's quite common for multipole lever operated devices to be made up of single pole devices riveted together with a crimped on profile or a pin linking all the levers together, so that they all operate together.
Reply to Is this meter installation ok? in the UK Electrical Forum area at ElectriciansForums.net
Nope no fuse or MCB located anywhere apart from of course the 100A main head. I would assume they’ve used the rotary isolator just as a means to...
All good thanks, still trying to retire but still finding myself busy as ever. Hope you're well.
Recommended Sponsor News
Hi everyone,
