Is this possible? | on ElectriciansForums
Discuss Is this possible? in the Australia area at ElectriciansForums.net
M
MrTrance
Could I power a light (maybe 60 or 40 watt bulb) using a bit of twin and earth on a 5 amp plug, straight into 230 mains?
I need a light in my loft and want to rig something up?
What size cable do I need and is 5amp fuse correct?
of course you could do it, but depending what method you use, it might not comply with regs. Thats if you actually care about regs. But just use 1.5mm2 t+E. On a 6A circuit breaker. Or if your coming off a spur use a 3 or 5A fuse. Your'e also better off putting a pendant up on a ceiling rose rather than a 5A socket
^ im only first year at college, so most of that doesnt make sense lol. I mean just a light bulb wired with a bit of 1.5 of to a fused plug so I could plug it into an extension from my loft and then onto a socket on second floor?
MrT you are
better off buying a ready made up inspection lamp,comes with plug and several meters of flex,and often comes with a guard around the bulb and even a hanging hook,save you having to mess about with things you might damage yourself with,such as electric.
Twin & Earth shouldn't be used with a plug because it isn't flexible enough.
If it's a temporary measure you'd be better off using an inspection lamp, otherwise seeing as it's in the loft you could probably loop on from the upstairs lighting circuit.
Be careful though...
Reply to Is this possible? in the Australia area at ElectriciansForums.net
The same socket can be used for different appliances, such as kettles... which will draw more than 5A The size of the cable determines how much...
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
