Is this right? Switch fuse spur | Page 2 | on ElectriciansForums
Discuss Is this right? Switch fuse spur in the UK Electrical Forum area at ElectriciansForums.net
littlespark
Staff member
Supporter
Patron
Solutions
Scottish Borders
Customer supplied shiny metal accessories, varilight through TLC.
the switch fused spurs are prebuilt from grid components, but where they have put the link, it shows line supply into fuse first, then through dp switch. Neutral only goes through switch.
I thought it would go through switch first, to isolate the fuse if you need to pop it out.
ive fitted them as is, as that’s how they’ve been supplied.
[ElectriciansForums.net] Is this right? Switch fuse spur
Come to think of it…. Shouldn’t it be a brown coloured link?
It's done supply-fuse-switch so that if the switch is illuminated, a blown fuse would mean the indicator would be off. If you wire it switch first, then the switch will be lit up (when on) even if the fuse is blown - confusing for the user.
If illuminated, the indicator is integral to the switch.
Reply to Is this right? Switch fuse spur in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
