Is this safe? | on ElectriciansForums
Discuss Is this safe? in the UK Electrical Forum area at ElectriciansForums.net
Tre390
UK
Hi everyone. I just had an electric toilet seat installed (bidet - warms and shoots water, heats seat, etc). I think some protection was installed on the cable run (rcd?). However I noticed under the cistern some tape was used with the toilet seat cable and main electrical supply.
Is this safe?
Here's a picture:
[ElectriciansForums.net] Is this safe?
Thanks to anyone who can help.
sounds like it’s outside the zones, or sounds like it’s a big bathroom!
sure that’s not 2 FEET from the shower?
That connection should definitely be in a box, especially if mains voltage, but it could be ELV without being able to check.
Rough as a badgers.....
Better check it has an RCD and it’s tested frequently.
Yes 2 metres, it's a wide bathroom, the shower and toilet are on either side.
ELV? I'll send a pic of the wires with tape unwrapped too when I get home.
Reply to Is this safe? in the UK Electrical Forum area at ElectriciansForums.net
Silent Running Toilet eluding capture I have three toilets in the house. Two have been "silent running" for a while now (constant trickle of water...
slocombe9
https://www.d-line-it.com/u-clips/
2 3
