Is this the purrrfect chase? | Page 2 | on ElectriciansForums
Discuss Is this the purrrfect chase? in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
little info. socket on right was an existing single, mounted on a 16mm box!.left socket is new. ideally I'd have raised the existing socket to the same height, but cable is in steel conduit. didn't fancy cutting that with a cable inside. trainees note that the change of height was done in the corner safe zone.
chase was cut using a multitool to save dust. got through 2 saxton blades though. note that I cleaned up after me, unlike some sparks I know.
  • [ElectriciansForums.net] Is this the purrrfect chase?
I keep all the old used blades for my multitool and use a grinder with a 1mm disk on to put some teeth back on them. Amazing how many times you can do it and it makes a huge difference in the time spent cutting with dull blades
I gave that a go freehand.... Did a terrible job of it!
Reply to Is this the purrrfect chase? in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
