Is this twisted cloth flex double or single insulated? | Page 3 | on ElectriciansForums
Discuss Is this twisted cloth flex double or single insulated? in the UK Electrical Forum area at ElectriciansForums.net
Aberdeen
Hi Folks
Just bought some of this Bronze Twisted Fabric Flex - Braided Cloth Cable Lighting Wire - https://www.industville.co.uk/products/light-brown-twisted-fabric-flex-braided-cloth-cable-lighting-wire?variant=1184660808&gclid=EAIaIQobChMI14zguOzl3wIVRbDtCh2C9QQCEAkYASABEgJA0fD_BwE for a job. The description says double insulated but the BS EN number quoted is for single. I've received it and there is one layer of plastic (presumably PVC) insulation and the woven sheath. Does the sheath provide the double insulation as the seller seems to imply? I'm a little bit dubious.
Does anyone know which BS (EN) standard is applicable to such a cable (for use as part of a chandelier with chain to bear weight)? I've been looking at the titles for the BS EN 50525 series and think this one may be right: BS EN 50525-2-82:2011 Electric cables. Low voltage energy cables of rated voltages up to and including 450/750 V (U0/U). Cables for general applications. Cables with crosslinked elastomeric insulation for decorative chains. Any thoughts?
Silly question. Why does it need to be 'double insulated' for your application?
It needs to be sheathed as it will not be in a conduit or similar. I take that to mean the sheath has to be able to act as insulation if the inner insulation fails. I have bought some of the cable Vintage Lights as linked above. Each core has two distinct layers of PVC (or similar, I haven't chemically analyzed it!) insulation within the braided outer sheath. It's product code is TM05 that lots of others sell, whereas Industville's is FL-T-BZ which no other supplier seems to think is a cable. Draw your own conclusions.
Reply to Is this twisted cloth flex double or single insulated? in the UK Electrical Forum area at ElectriciansForums.net
