a domestic electrician was employed by the contractor to install extra emergency lights to existing lighting circuit within a plant room
the existing lighting circuit is wired in 1.5mm FP200 cable and fixed to cable tray for suspended ceiling and wall lights
the electrician used 1.5mm flexible cable tapping off from existing emergency lights
the longest run is 6 metres
the electrician claimed the flex is heat resistant and therefore acceptable
is he correct ?
is he correct ?
