island in kitchen | on ElectriciansForums
Discuss island in kitchen in the UK Electrical Forum area at ElectriciansForums.net
England
As some of you guys know my week end project still on the go. Turns out family owner of house now requires an island worktop /cupboards in the kitchen. In the island 1 x oven and 1 x hob (both electric) and LED lights in kick board. I'm wiring 2 X cooker circuits. I know an induction hob will be installed but don't know the loading. I propose to install 2 x 45A DP switches above the worktop on main wall as per norm. Appliances will be with the 2m rule (if in fact it that rule still exist). My question is, what is the best method / practice to get the cooker cable from switch to island via u/g. Underfloor heating be installed, overall depth of floor is 175mm incl insulation which has not been installed as yet. I was thinking of 6mm 6242Y cable enclosed in some pvc flexible ducting (ploy duct or similar) .The LED lights same way but from a sw/spur.
wet heating or electric? if insulation is going below the heating, then if the cables( in a duct ) are a few inches below that, should not be a problem.
Would have thought underfloor heat and PVC flexible conduit not a good mix
Yes..know what you mean..........ducting /cable will be on concrete slab insulation on top then heating pipes. As underfloor heating, the heat will be spread over a large area therefore the actual temperature will not be high. hopefully guys on here that are use to wiring kitchen islands can steer me in the right direction. Many Kitchens are done this way. I've not done any.
That'll be 100mm insulation plus 75mm concrete on top probably.
Typical temperature of the water in U-floor is 40c.
The underfloor pipes won't be laid under cupboards or the island.
Lay the duct on the concrete and clip it down or it will move, then the insulation can be laid over the top of it.
Hi,you cannot guarantee this,as proper calcs and install for wet U/F,is ALL the floor area with margin at perimeter. I know,this depends on situation and installer,abroad,and where it has been used for generations,they do this,then insulate where not wanted/required,such as cupboards. Installing wet U/F is a major task,and is only done correctly,either new-build or retro,in conjunction with other design features,insulation being the biggest consideration. Kitchens are swapped and changed many times during a properties life,and to design a wet U/F system just to suit one,present kitchen,would be short-sighted. Anywho...i digress,it should be possible to design some type of ducting,to facilitate your required cabling needs,regardless of U/F pipe runs.:conehead:
I'm doing a kitchen on thurs and fri this week, has an island too.
He has channelled out a slot about 6" wide and 3" deep, Its going to have pipes in one compartment and a few cables in the other, they will be spaced apart so I would imagine it will be fine.
Reply to island in kitchen in the UK Electrical Forum area at ElectriciansForums.net
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
