Isolate Light to find Live Plug | Page 3 | on ElectriciansForums
Discuss Isolate Light to find Live Plug in the UK Electrical Forum area at ElectriciansForums.net
Cornwall
I
Went to isolate light & found this.
This has been rectified.
What further action would you take?
[ElectriciansForums.net] Isolate Light to find Live Plug
I don't really get this post. It is quite long winded now and I admit I have not studied it in anything other than a quick read through, however are we not forgetting some basic principals here? Lighting circuits, are responsible for killing more "electricians" than any other, apparently. Not sure where I read that but I can well believe it. I have witnessed in my time some unbelievably stupid setups done by previous "sparks" and DIY folks alike. Personally, if someone put a down-lighter in front of me now on my sofa I would look at it and think "i'll test that before I grab hold of it". I realise some plonka has probably done something really stupid that is worth reporting, but at the end of the day don't grab hold if it until you know its safe. I am always VERY wary of anything to do with lighting or lighting circuits, just a tip.
To the OP what actually made you test this? were the lights still lit?
Cheers Mykey
When I'd pulled the plug to isolate, the light was still on. (It can be seen in the photo)
The feed came into a jb, to a pir, to jb, back to the light, then flex to light plug.
The plug was live & used to back feed the socket, to feed the other lights!
If that is the case, it will be the Fall to the ground that caused the death.
And probably caused by completing a broken neutral path as well.
It's not far to fall if you're working on a socket or control panel.
Good job the tubes had not gone then. I have been working on lights for the last few days all on clix and obviously up at height each light is on its own clix but I have seen them daisy chained in the past.
Reply to Isolate Light to find Live Plug in the UK Electrical Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
