View the thread, titled "Isolators for Gas hob ignition" which is posted in Australia on Electricians Forums.
J
JohnCC
hi there,
I'm replacing my kitchen and removing a freestanding electric oven/hob for a gas hob and an electric oven.
The freestanding unit is on it's own line from the mains on a 32A fuse covered by an isolator in the kitchen.
Can I put a plug socket onto the oven line and put the hob ignition on it (it only needs a 1A)?
This way the oven isolator would also protect the ignition.
The other alternative is to extend the kitchen loop for the ignition - but then I would have to add my own isolator and that seems a bit overkill.
What do you think?
Kind regards,
John
hi there,
The freestanding unit is on it's own line from the mains on a 32A fuse covered by an isolator in the kitchen.I can only assume you are going to connect the new oven onto this supply, you will need to take into account the load of the new oven before you think about adding sockets to the circuit.
This way the oven isolator would also protect the ignition. If your going to fit the new oven to this circuit, does the manufacturers instructions ask for a dedicated circuit ?
The other alternative is to extend the kitchen loop for the ignition - but then I would have to add my own isolator and that seems a bit overkill. When you say "kitchen loop" is this for the existing socket circuits? Why do you need an isolator on the ignition unit, they are normally either internal battery powered or they plug into a normal 13amp socket which will be your isolator.
What do you think?
Kind regards,
John
As above but there are other things to consider here.
1 Do you have RCD protection and does the new unit call for RCD protection.
2 Do you live in England or Wales and therefore subject to Part P of the regulations.
Reply to the thread, titled "Isolators for Gas hob ignition" which is posted in Australia on Electricians Forums.
