"I've got no hot water!" - Call out | on ElectriciansForums
Discuss "I've got no hot water!" - Call out in the Electrical Course Trainees Only area at ElectriciansForums.net
J
Jamie
Got a call out today, No hot water, I get one of these call outs every couple of days, sometimes several in one day...
Turn up, Ask where the consumer unit is, water heater switch & tank is, go to the tank, take a look inside the cupboard and see a right state, electrical burning smell too...not a good sign to start off with haha, so back to the consumer unit and switch off so I can take the cover off and investigate...
http://i.Upload the image directly to the thread.com/kawcJiEl.jpg
No flex grip resulting in the Neutral being pulled out of it's terminal (I don't know why it wasn't doubled over, so the terminal screw/plate gets a even hold each side like you would a bonding clamp)...
http://i.Upload the image directly to the thread.com/6AnWheyl.jpg
http://i.Upload the image directly to the thread.com/7oQDqA9l.jpg
http://i.Upload the image directly to the thread.com/kbnzp7Nl.jpg
http://i.Upload the image directly to the thread.com/Ct4lNkgl.jpg
Re bared the cable, terminated it and made sure it was all working ok, got a new flex grip out the van, couple of screws, got to nip back tomorrow with a new cover as we don't stock them! So put the old one back on for time being!
I've never seen a immersion heater thermostat housing that bad....to the point where the actual round cover melts..
Did a RCD test and all came back OK....So I suppose the neutral just didn't touch the earth/metal casing, as it never tripped of? I was wondering why the RCD was still holding for a start before taking the cover off, as soon as I opened the cupboard door I could hear it buzzing away :ears:
Just thought I would share that with you guys anyway, Anyone ever seen a worse thermostat housing?
Yep, typical of poor terminations on circuits that carry a reasonable current. It's not uncommon to see the lid or housing/enclosure melted as well as the insulation around the guilty termination.
You'll also com across similar damage inside appliances such as ovens or washing machines. Often they use those insulated blue ring terminals or lugs and they're only rated to 10 Amps. The uninsulated lugs are better and can carry higher current.
**edit** Nice clamp meter by the way, I wish mine was as clean and shiny as yours :)
Thanks haha, It's only a cheap one (well free from the work store haha), comes with a leather case too :) about the only tool I have acquired and not bought
Reply to "I've got no hot water!" - Call out in the Electrical Course Trainees Only area at ElectriciansForums.net
can you post a picture of the heating element? if possible with the power off and the cover off.
It maybe a case of the display has died, especially if the unit is actually working, but as James has said you could be opening a can of worms...
