Joining erthernet cables | Page 4 | on ElectriciansForums
Discuss Joining erthernet cables in the UK Electrical Forum area at ElectriciansForums.net
Midwest
Nearly Esteemed
Oxfordshire
Following on from my other thread
IP rated switchcover - https://www.electriciansforums.co.uk/threads/ip-rated-switchcover.173742/
I’ve decide to try and relocate the control panel. After a bit of a faff, managed to get to the other side of the old control panel. So my intention is to extend the two existing erthernet or network cables to the new position.
Having never worked with the stuff, what is the best method and product to use to join them? I’ve seen some vids of just twisting the cores, but that seems a bit of a bodge.
I’ve also seen coupler boxes, which look just like telephone line boxes. Is just as simple as that?
I
If ALL the wires are doubled up with their partners (e.g. blue with blue/white) you don't have Ethernet. But it is permissible to double up brown with brown-white and blue with blue-white since there four are unused except by Gigabit Ethernet.
Here’s a pic of back of panel;
[ElectriciansForums.net] Joining erthernet cables
That’s the 12v power supply and rs485 communication(d- d+)
rs485 is also known as multi drop serial coms.
each device on the network has its own address, devices can send and receive info to each other down a single pair of wires.
normally at 1 end, there is a terminating resistor so if you need to extend it then you have to do it from the last device in line and move the terminating resistor to the new end of line device.
There is a terminating resistor at both ends.
Sounds like Token Ring.
It’s not clear in this thread, but the existing panel is in the confines of a swimming pool. The replacement needs relocating by about half a meter to the other side of an entrance door, in a more suitable environment.
You said EX-0R but that switch doesn't say that have you got a picture of the control box.
The original installers quoted panel and part number, which was from Ex-Or. The product boxing states Ex-Or, but the new panel has Philips written all over it. I was a bit concerned, but apparently all this stuff is manufacturer & marketed by all sorts.
Reply to Joining erthernet cables in the UK Electrical Forum area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
