Joint cables inside back box? | on ElectriciansForums
Discuss Joint cables inside back box? in the UK Electrical Forum area at ElectriciansForums.net
M
Mynamesmatt
I have one double socket in my kitchen (its part up the upstairs ring) ...and i need to change it to three doubles
Is it ok to use the double back box that is currently in the wall, to joint and extend the ring (and place a double blank plate over) then chase down and fit three doubles?
If so what type of connectors should i use, wagos?
Be nice ...........
[ElectriciansForums.net] Joint cables inside back box?
im a qualified electrician! the original socket is far too high above the worktops, just all needs re-jigging really
thanks guys!
also, i came across a lighting junction box under the floorboards.. all the terminals inside were being used by live/neturals and so someone has brought the earths OUTSIDE the jb and put them all into a chock block.. anyone ever seen this done? hmmmmmmmm
Sorry matt, didn't know you were a qualified electrician. I'm surprised you are asking about extending an RFC in that case. Not part P tho?
In answer to the JB question, yes, you will find that method used throughout thousands of homes. Not good practice, and one which I hate, but out there nonetheless.
You've got it dead right matt, nice picture. Doesnt matter what you have behind the blank plate (crimps, terminal block, wagos) its all good although I love wagos these days. I wouldn't worry too much about that Part P nonsense, its your gaff and if you know what you're at then crack on.
On the subject of wagos
Anyone who has never use a wagobox/connectors please please give them a try you dont know what you are missing out on.
Picture this: 4 T&E's and 2 3 cores hanging out of a 70mm downlighter hole all need connecting together in an enclosure that will fit back through that hole.......major headache right...not with a wagobox and connectors. Literally takes about 10 minutes and only tool you need is cutters, no tape no drivers nothing.
Awesome awesome awesome
so what if its 5A connectors....as i found the other day in a similar scenario?
if it's exactly above the new socket, cut a bit of metal capping down and place it over the connections then plaster over it. I see no reason why that can't be done because it's still in a safe zone, that's only if your using maintenace free connections though
I don't like that! I know it's ok cause it's mf but there's something about it I don't like and would never do myself
Reply to Joint cables inside back box? in the UK Electrical Forum area at ElectriciansForums.net
Thanks for all your input guys. It seems to be that it’s down to personal preference on the best thing to do/if it’s appropriate. In my head I...
An example of the long term race to the bottom of quality of work in our industry, IMHO.
